Nobody seems to know what i'm talking about when i ask for the sleeve that fits over the spinner shaft between the spinner support plate and the tub seal.Does anybody know what i'm talking about and where can i get it?:mad:
Take a look at this recent post FAV6800A/FAV9800A Outer Tub bearing . I call out some p/n numbers. You will get the sleeve you are asking about inserted in the new Tub Seal.
I have some pics that show the old sleeve from the tub seal clearly of my tear down about 18 months ago. Those pics along with a forum members pic’s of his Tub Seal, Tranny O-Ring and bearing replacement may help you if your are doing a Tub Seal replacement.
If you are in the process of replacing the Tub Seal in your machine and can tolerate some extra down time you may want to look at doing a bearing replacement of Outer Tub bearings and Spinner Support bearings.
What are the first two digits of the S/N of your machine it will be in this range 10 thru 17?
Dick
