freezer works but refridgerator does not replaced the fan motor but still not cold:(
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
replaced fan motor but still not cold no frost
Originally Posted by: nanny4280 replaced fan motor but still not cold no frost please help
Check the air damper, this is located in the fresh food section. If you have a good frost pattern and the freezer fan is running the air is being blocked, usually the damper is iced over. Check that out were here if you have any more questions. Appliance Repair Technician:
