FISHMASTER70
#1 Posted : Wednesday, September 17, 2008 5:13:47 PM(UTC)
FISHMASTER70
dryer will run for a few minutes and stops. all lights will light up after it stops. if not running all lights on cycle knob will bink then go off about every 2 to 3 minutes. i think it is the main board behind cycle knob but not sure
libertyappl
#2 Posted : Wednesday, September 17, 2008 5:32:48 PM(UTC)
libertyappl
Try this it's straight from the service manual.
nat
Runs a few minutes and then stops:
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
FISHMASTER70
#3 Posted : Wednesday, September 17, 2008 5:49:41 PM(UTC)
FISHMASTER70
i have already tried all of them even tried to clear service codes ,console switch test and the service cycle test. but while i'm going through the steps all lights around cycle knob will blink and knocks me out of service mode. the cycle will go back to regular cycle dryer will run a few minutes and stop again.
libertyappl
#4 Posted : Wednesday, September 17, 2008 5:55:52 PM(UTC)
libertyappl
If you want I can post the whole manual maybe that would help.
Nat
FISHMASTER70
#5 Posted : Wednesday, September 17, 2008 6:20:02 PM(UTC)
FISHMASTER70
why cant i go through any of the service codes, switch test, are clear any of the codes. dryer was working fine until i lost power for the storm. dryer worked for a day after power was restored then went crazy. can u tell me what it means when all the lights light up there is no code for that in the manual i have
FISHMASTER70
#6 Posted : Wednesday, September 17, 2008 6:25:51 PM(UTC)
FISHMASTER70
i chcked all limits only one of them does not ohm out tried to jump it out but dryer still does the same thing. the limit the does not ohm out is next to the blower even tried jumping out the sensor on the lint trap but drier still does the same thing
libertyappl
#7 Posted : Wednesday, September 17, 2008 6:28:22 PM(UTC)
libertyappl
I'm not sure, usually if it was from the storm it would have been an immediate issue.
If you've checked everything and it won't go into diagnostics, I'd have to say it's probably the control board.
Nat
FISHMASTER70
#8 Posted : Wednesday, September 17, 2008 6:31:07 PM(UTC)
FISHMASTER70
thats what i was thinking thanks for the help
libertyappl
#9 Posted : Wednesday, September 17, 2008 6:34:37 PM(UTC)
libertyappl
Wasn't really much help, but You're Welcome!
Guest (5)
Dryer runs for a few minutes and stops. (Dryer Repair)
by george.henne 1/30/2011 10:21:37 PM(UTC)
