J Kreimer
#1 Posted : 14 years ago
J Kreimer
I have a basic whirlpool dryer,Model #WED5300SQ0 that is about 2 years old. The timer stopped working. When I start a load the timer does not move and the dryer never heats up. I have tried different setting and none of them are working. Any suggestions? Is it just the timer or control board behind it or thermostat or any other possibilities?
#2 Posted : 14 years ago
A Model number may help others help you.
When you say you tried different cycles did you try timed dry and auto cycles? Just watching to see if the timer advances.
J Kreimer
#3 Posted : 14 years ago
J Kreimer
Model # WED5300SQ0
J Kreimer
#4 Posted : 14 years ago
J Kreimer
The model number is WED5300SQ0.
J Kreimer
#5 Posted : 14 years ago
J Kreimer
I have tried different setting and sometimes they would move but now they do not.
#6 Posted : 14 years ago
Here is the parts breakdown.
Replacement parts for WHIRLPOOL WED5300SQ0 29``ELECTRIC DRYER | AppliancePartsPros.com
See the attachment for your wiring diagram.
The first thing I would check is the power.
The timer is connected directly across the 240 volts is timed dry through Timer Switch 0 contacts TMtoWB and the heater also requires 240 so odds are that you do not have 240.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
WED5300.pdf (506kb) downloaded 18 time(s).
