Originally Posted by: mcdowell_112 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a frigidaire range unit it will call for bake and broil but will not heat is the board bad?model #FEF326BB.The top elements work fine and I have power coming to the left side of elements but not on the right side. Very likely the problem is a bad EOC. If you need the correct part number, verify the model number you posted. You missed some letters. Gene.
Originally Posted by: jsw9674 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene, I have a similiar problem and it sounds like the EOC needs to be replaced. I heard a pop and the stove works, but not the oven. Is this something I should be able to replace myself (as I'm fairly handy) and should I go through specific checks before purchasing the EOC? Also, any advice on what to do/not do when replacing the EOC? Thank you for your time. Jim Jim, Sorry I missed your post. If it is not too late what is the complete model number of the range? Gene.
Hello Gene
Wishing you well. I have a Firgidaire gas range/electric oven (mod#plcf489cc) in which the symptom is simply no 240v to bake element. The warmer, convection and broiler appear to work. There are two seperate relays, seperate from the EOC. Is there a way to test these relays? I don't know what's next. Thank you for your time. anthony
Hi Anthony,
I'll be more than glad to help but you missed the last letter in the model number. Verify and repost it please.
Ah-ha! Thank you, Gene for your attention. I am missing a 'C'. Here is the whole thing. Model#PLCF489CCC I appreciate and look forward to your help. anthony
Anthony, There is nothing else but the EOC what can cause such problem ( wiring diagram), especially if there is only one 120 VAC leg to the Bake element is missing. - The EOC Part number: AP2127066
Gene, Thank you very much! Confirmed my intial thoughts, I wasn't certain. Thanks again! anthony
You are welcome Anthony. Keep us posted.
I have an Electric Range model FEF366EMC. The broiler (top element) works fine. The stove top (all 4) work fine. But the bottom element in the oven doesn't work! What gives??? I can't live without my oven!
