How do I replace a leaking gasket in the front door of the washer? Is it easy or hard? Will I need any special equipment? Dr. Jaffe
Originally Posted by: bjaffe80 How do I replace a leaking gasket in the front door of the washer? Is it easy or hard? Will I need any special equipment? Dr. Jaffe Dr. Jaffe, No, you won't really need special tools, It's not a really hard repair to perform, Here are excerpts from the service manual, and a part number for the bellows Part number: AP4379904
REMOVING THE CONSOLE AND THE TOUCHPAD/LED ASSEMBLY 1. Unplug washer or disconnect power. 2. Turn off the water supply to the washer. 3. Remove the three T-20 hex-head Torx screws from the top cover of the washer. 4. Pull back on the cover and release the tabs in the console from the slots in the cover, then lift the cover off the unit.5.
To remove the console: a) Pull out and disconnect cable connector UI8 from the central control unit. b) Remove the cable wires from the two central control unit clips. c) Pull the detergent dispenser drawer out as far as it will go, then press down on the release tab, and remove the drawer from the unit. d) Remove the one screw at the recessed hole. e) Lift the top edge of the console and unhook it from the holder clips. f) Press the locking tab on the right rear side of the console inward, and remove the console.Removing the front panels10. Remove the three hex-head screws from the lower front access panel, then lower the panel, and remove it. 11. Open the washer door.
12. Using a small screwdriver or a pair of long-nosed pliers, pull the tension spring on the retaining wire out from around the front of the bellows, and remove the wire. 13. Pull the bellows off the lip of the front panel, and push the bellows inside the front panel. 14. Remove the two T-20 Torx screws from the door switch assembly. 15. Close the washer door. 16. Remove the four hex-head screws from the top and bottom of the front panel and remove the panel from the unit. 17. Loosen the clamp from the main water feed tube and remove the tube from the detergent dispenser. REASSEMBLY NOTE:
When you reconnect the water feed tube, align the arrow on the tube with the line on the detergent dispenser. 18. Pull back and unhook the tab on the left side of the detergent dispenser from the cabinet side panel slot, then lift the dispenser out of the washer.To remove the bellows:
c) Turn the bellows retaining clamp screw counterclockwise until the clamp is loose enough to remove it from around the bellows NOTE: It may be necessary to completely remove the screw from one end of the clamp.
d) Remove the bellows retaining clamp from around the bellows
e) Pull the bellows off the front of the tub. Remove Bellows REASSEMBLY NOTE:
When you reinstall the bellows, be sure to position the “weep holes” at the bottom. It looks and sounds worse than it is.:) :) :)
