mmshrader
#1 Posted : Thursday, January 27, 2011 6:39:40 PM(UTC)
mmshrader
The dryer cool down cycle does not work, clothes come out wrinkled.
#2 Posted : Friday, January 28, 2011 1:40:36 AM(UTC)
Replacement parts for MAYTAG MDE4000AYW DRYER- ELE | AppliancePartsPros.com
Here is a service manual
16023110 Maytag Sloped Front Dryer Repair Service Manual - ApplianceDigest.com
You will have to join the site to download the manual but it is a very good site for info.
First I would check that the heating coil will shut off in an air only cycle.
If not you may have a grounded element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to be on and the thermostats/switches cannot regulate it.
mmshrader
#3 Posted : Friday, January 28, 2011 7:22:59 AM(UTC)
mmshrader
Originally Posted by: denman Go to Quoted Post
The dryer drys fine, the only problem I have is with the cool down cycle do I need to check the heating coil?
#4 Posted : Friday, January 28, 2011 7:44:52 AM(UTC)
[COLOR="DarkRed"]The dryer drys fine, the only problem I have is with the cool down cycle do I need to check the heating coil?[/COLOR]
Yes because if it is grounded it can still heat OK, depends on where and how it grounds. But it will not shut off and that is required during the permanent press cool down.
mmshrader
#5 Posted : Friday, January 28, 2011 10:05:15 AM(UTC)
mmshrader
I checked the resistance and I have 10.7 ohms across the heater and from each side to ground I have infinite resistance.
#6 Posted : Friday, January 28, 2011 2:08:29 PM(UTC)
OK.
Are you sure that the heater is staying on for the whole cycle?
This is something I am sure you have already checked but it never hurts to double check things.
It looks like the heater gets power through the timer contact set 3.
If you look at the timing chart page 10-3 in the manual they open before the drive motor contact set 1.
Unplug the unit, remove one wire/side of contact set 3 and measure across the contacts.
Manually move the dial to see where/if they open.
mmshrader
#7 Posted : Saturday, January 29, 2011 12:25:19 PM(UTC)
mmshrader
OK.
I found that the timer contacts were fused together, I burnished the contacts and reassembled the timer and I will try it out tomorrow
thanks You were a great help thanks Mike
#8 Posted : Sunday, January 30, 2011 1:41:45 AM(UTC)
You are welcome
Mike Stewart (Dishwasher Repair)
by mstewart8840 10/20/2011 8:04:19 AM(UTC)
mike s (Microwave Repair)
by midy8@att.net 11/17/2008 1:39:31 PM(UTC)
