207 Pages«<1314151617>»
gnuage
#141 Posted : Thursday, September 11, 2008 6:35:02 AM(UTC)
gnuage
Gene,
After reading this document at: http://www.servicematters.com/m...ibrary/docs/16010154.pdf . I realize that by setting the freezer to 9 (the coldest) actually reduce the air flow to refrigerator to minimum. Last night I set the freezer setting to 2 and this morning the refrigerator cools down to 39 F. Everything seems to be working now. I will let it run for a week to see if it holds.
Frank
#142 Posted : Thursday, September 11, 2008 12:48:07 PM(UTC)
Frank,
I bet you fixed the problem. Good job.
tracy1
#143 Posted : Monday, September 15, 2008 8:22:07 PM(UTC)
tracy1
Hi GENE, i have similar problem IE the freezer is fine but the refrigerator is too warm. we did try to unplugged the frig overnight and restart the next morning . no result so fa. ours is a GE prfile artica model PTS25SB . ANY suggestions , advice? thanks tracy1
sam_crx
#144 Posted : Tuesday, September 16, 2008 3:55:47 AM(UTC)
sam_crx
am sorry if my english is not good
i got LG GR-359SQ MULTI AIR FLOW the freezer looks fine but the refrigerator part is warm then I took the cover off and I sow massive ice build up on the lower part of the evaporator tube or evaporator coil then I defrost the ice its worked good but again after 20 days happen same problem again I defrost now until now three times happening same plizz help me if u know the problem:(
#145 Posted : Tuesday, September 16, 2008 12:39:46 PM(UTC)
Tracy,
Did you see frost built-up in the freezer?
#146 Posted : Tuesday, September 16, 2008 12:45:49 PM(UTC)
Sam,
This is a duplicated post.
Answered here: http://forum.appliancepartspros...ce-build-up-problem.html
CoreyD
#147 Posted : Tuesday, September 16, 2008 5:01:38 PM(UTC)
CoreyD
I have a Maytag model MZD2766GEW. Several months ago I had a defroster issue that, with help from posts here I was able to repair. I left town for a week and just returned to a mess. My fridge does not seem to be cooling at all, freezer or fridge. No ice buildup on freezer side. The condenser fan is running, and the compressor seems to be coming on, although it seems to cycle on & off quite often.
Any help on what else to check?
Thanks,
Corey
#148 Posted : Wednesday, September 17, 2008 1:13:27 PM(UTC)
Originally Posted by: CoreyD Go to Quoted Post
...the compressor seems to be coming on, although it seems to cycle on & off quite often...
Hi Corey,
How often? Are we talking about minutes or seconds?
CoreyD
#149 Posted : Wednesday, September 17, 2008 2:21:08 PM(UTC)
CoreyD
Gene,
Thanks for getting back to me. I just went out and plugged it in. I am hearing a click (solenoid?). The compressor seems to be coming on for 15 or 20 seconds, then off for a minute or two. Then repeats. The compressor seems to be very quiet. I place a screw driver against the housing and with my ear against the screwdriver handle I can hear a hum.
Does any of this help?
Thanks again,
Corey
#150 Posted : Thursday, September 18, 2008 12:37:20 PM(UTC)
Corey,
The first thing I would do is replace the relay and overload for the compressor. If it would not help then the compressor itself is bad.
- The part number for the relay/overload kit is AP3964068
If the problem is a bad compressor then this job has to be done by a certified technician.
Here are the break down diagrams for the Maytag refrigerator Model MZD2766GEW
Guest (18)
