Dale
#1 Posted : Monday, October 1, 2007 3:14:13 PM(UTC)
Dale
Gas will ignite when dryer first started and dryer will heat up. After a little time, dryer gets cool and will not reignite. After leaving dryer off for a bit, same thing. Heat, then no heat.
I have had the back off. Venting is clear and I have checked the cycling thermostat, thermal fuse and high limit thermostat. I've never done this before. The directions for the tester I bought said when set on RX1, they should read zero, which all three did, except when I put the the cycling thermostat on a heat source, then it read infinity. The only odd thing was when testing the high limit thermostat, it didn't read zero right away. I had to leave the tester probes on it for a few seconds before the meter went all the way to zero (totally a novice here so don't know what's important).
Needless to say, put the dryer back together and nothing solved. I've read a few posts and saw gas coils mentioned. Where should I start next?
richappy
#2 Posted : Tuesday, October 2, 2007 2:54:31 AM(UTC)
richappy
Pull front panel off and remove drum. Monitor the main gas electrical connector with a meter. Start dryer, if voltage is steady when the flame goes out, you have bad gas valve coils. Click on your model # above to get part #.
Dryer heat problems (Dryer Repair)
by gmckinley 6/14/2013 8:46:54 PM(UTC)
intermittent dryer heat problem (Dryer Repair)
by busterhead 10/19/2012 2:28:25 AM(UTC)
gas dryer heat problem (Dryer Repair)
by SPRISL 7/6/2010 10:53:01 AM(UTC)
by ribwholesalers 7/8/2009 1:44:21 PM(UTC)
by wtelwe 2/10/2009 6:42:48 PM(UTC)
