dinop
#1 Posted : Wednesday, January 12, 2011 3:42:42 PM(UTC)
dinop
The microwave is not heating food up and at the end of the cycle, it does not beep
#2 Posted : Wednesday, January 12, 2011 5:10:07 PM(UTC)
Does it make any unusual sound?
Do the turn table and the interior light work while the microwave is on?
Here are the breakdown diagrams and Replacement parts for General Electric JVM1660SB005 Counter top microwave | AppliancePartsPros.com
dinop
#3 Posted : Thursday, January 13, 2011 2:28:15 PM(UTC)
dinop
Everthing else works its just the button and the heating in the microwave that does not work. i need to know what the part is.
#4 Posted : Thursday, January 13, 2011 3:27:47 PM(UTC)
If you feel comfortable to work with the electric parts and you do have a multimeter, do the following:
Open the control panel. If you can access the high voltage transformer, remove the wires from the transformer primary winding and check for 120 VAC between these wires while the control calls for heat and the door is closed.
If there is no 120 VAC, replace the control board.
If there is 120 VAC, then most likely the problem is a bad magnetron.
If there is no access to the high voltage transformer through the control panel, then the microwave has to be removed from the cabinet and the microwave outer case has to be removed.
- The control board Part number: AP2631621
- The magnetron kit Part number: AP4564705
