There's a big copper looking fuse mounted on the top of the microwave - that one is fine. There's also a glass one on the left of the control panel circuit board which is also fine.
Thanks.
Check the door switches and, if there is nothing wrong, then the magnetron most likely is bad.
It looks like the part number is AP3109457. Is this something that is straightforward to replace? ie diy or professional? Thanks
Yes, this is the right part number for the magnetron.
This job is not too complicated to do it yourself. Most difficult part is to remove the microwave from the oven cabinet. You'll need to disconnect a lot of wires. Mark them properly to avoid problems with assembly it back.
Be careful and do one thing at a time and you can fix it.
I will let you know how it goes.
My magnetron arrived. Do you have any tips or pointers on getting the Microwave out?
I replaced the Magnetron, the microwave is still not heating. I did find from the service manual that when I press the Cancel a code F ' R1 appears on the display on the microwave side of the control panel.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Check the door switches... Did you do it? Gene.
Not correctly I suspect. I'll check again.
