dryer runs allthe way through to off but continues to run ,buzzer sounds timer stops, heat is off , there is no power to timer motor but dryer continues to run?
thank you herman
Seems like a bad timer with sprung contacts. Call AppliancePartsPros for order info.
i was given this part #ap278251 for model # admiral inc7745a71, my questin is the old timer has a rectangler , ceramic resister will i have to remove it and solder it to the new one, i just want to be sure i've got the right part.before iorder it. thank you herman
You might not have the right part, just call the supplier.
Rank: Administration
ap278251 is the right timer for LNC7745A71. The resistor is available separately:
