2 Pages<12
Fix it all
#11 Posted : Wednesday, December 26, 2007 11:14:14 AM(UTC)
Fix it all
Hmmmmm, Thinking.....Thinking.... Perhaps I'll just switch the hot and cold hoses!!!!!!!
#12 Posted : Wednesday, December 26, 2007 11:32:02 AM(UTC)
Most likely the problem is there.
Fix it all
#13 Posted : Wednesday, December 26, 2007 11:41:42 AM(UTC)
Fix it all
Working better than it ever has now!
Thank you!
#14 Posted : Wednesday, December 26, 2007 11:48:37 AM(UTC)
I'm glad you were able to fix it.
Happy New year!
debbieinroswell
#15 Posted : Friday, September 5, 2008 3:11:17 AM(UTC)
debbieinroswell
Most likely the problem is a bad water level switch (inside the control panel).
- The part number for the water level switch is AP2045895
Good luck.
Gene -- what if the water level switch is not the issue? Is there something in the wiring connections that can cause a false reading resulting in the water continuing to fill the machine (at any level selection)? I recently had a repair without this being a prior issue but became so immediately after the repair. After a revisit of the technician that reviewed his workmanship, the problem has not continued nor would he account for any action on his part that stopped the one time problem. By chance, do you know if there are any schematics on the wiring connections for the Load Size indicator? Thanks sooooooo much!
#16 Posted : Friday, September 5, 2008 2:08:39 PM(UTC)
debbieinroswell,
What is the complete model number of the washer? What exactly is going on now?
debbieinroswell
#17 Posted : Friday, September 5, 2008 2:33:34 PM(UTC)
debbieinroswell
The model # is [FONT='Calibri','sans-serif']WCSR2070T/VG4020. There were two broken tabs on the timer that allowed it to float so the repairman disassembled the controls from the control assembly plate and bolted the timer through it. He then reattached the controls and reassembled the machine. [/FONT]
[FONT='Calibri','sans-serif'][/FONT]
[FONT='Calibri','sans-serif']As far as currently, everything is operable however the very first load following a repair, the washer would not stop filling (on small level) and continued to fill for about an hour. [/FONT]
[FONT='Calibri','sans-serif'][/FONT][FONT='Calibri','sans-serif'][/FONT]
[FONT='Calibri','sans-serif']When the repair returned to inspect the machine, he immediately opened the control panel and checked / secured the wiring. I stayed in the room to see what he was doing to understand. As soon as he made wiring adjustments, the problem ceased and in 30+ loads since, has not reoccurred at any level. I am just curious if the wiring on the Load Size control incorrectly connected will push water through the system but miscommunicate the water level and continue to run. This was not a pre-existing issue nor has it been since the repairman returned. Just trying to understand and gets some peace of mind here. Thanks for the reply very much.[/FONT]
#18 Posted : Friday, September 5, 2008 2:56:34 PM(UTC)
The water level switch in your washer switches power between three wires and sends power to the water inlet valve as long as it reads insufficient water level and stops it as soon as it satisfied.
It was just a loose wiring connection somewhere inside the control panel. No doubt about it. As long as it was 30+ loads since, there is nothing to worry about.
debbieinroswell
#19 Posted : Friday, September 5, 2008 3:02:31 PM(UTC)
debbieinroswell
So it is possible that a false connection caused the machine to continue to fill that resolved itself when properly secured. Thanks!
2 Pages<12
