My microwave, when heating, flashes "door" on the screen. After that it will shut off, and i will have to restart it again. It will do this many times before the cycle is complete. Any advice will be appreciated. Thanks! :( :confused: :mad: ;) :o :eek:
In order to provide the most accurate advise I need the complete model number of the microwave.
The model number you posted is not a valid Whirlpool model number.
After entering the time and closing the door, this microwave fresh "Door" at the display. The only number I can get from the microware is Model/Part# 4450785A. I called the tech support at Whirlpool with this Model number, and they could find this issue on their computer. They mentioned something about a "fuse", but they refused to explain more nor tell me the part I need. What part do I need? Thanks, Best Regards
Check the oven door frame for the name plate with the model number.
Here is the number I found, hope it is the model number: GMC305PDB07.
The first thing I would check are the door interlock switches and the 20 amps fuse behind the control panel and the inline fuse. You can find the complete instructions on how to access and test microwave parts in the Service manual. Gene.
