liz777
#1 Posted : 14 years ago
liz777
My dryer turns on and runs but does not heat up on any setting. Thermostat, element, fuse, wiring? Easiest and cheapest way to find out which needs to be replaced?
kayakcrzy
#2 Posted : 14 years ago
kayakcrzy
You need to check all those parts, you just mentioned, with an ohm meter. It has to be one of the three you mentioned. Tom ApplianceEducator.com
#3 Posted : 14 years ago
Replacement parts for WHIRLPOOL YREX5634PQ0 29`` ELECTRIC DRYER | AppliancePartsPros.com
The first thing to check is the power.
L1 to L2 should be 240 volts
If OK
If OK
Once you know that the power is good then you can check the heating coil and thermostats with the unit unplugged using resistance on the meter.
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 11 years ago
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 13 years ago
by kamputty 15 years ago
by pauleouellette 16 years ago
by bseibes 17 years ago
dryer does not heat up (Dryer Repair)
by tkeemm 17 years ago
by dralonso 17 years ago
