Hi,
Remember to remove the racks before you self clean it.
Most of them you lock the door and then hit the clean button. At that time you can often select the amount of time you want it to clean for.
You have a thermostat knob on this over were you set the oven temp?
If so does it have a "Clean" position on it?
Hi thanks for the reply: yes the two knobs I know how to set, they both go on the little lock icons it's the buttons I have the problem with. There are no clean buttons and I can't remember what combination of buttons I need to push.
you can have a look at the control panel I have in the pic I included
