3 Pages<123>
sidfink43
#11 Posted : Thursday, December 30, 2010 3:57:15 AM(UTC)
sidfink43
Look inside the lower service panel. There should be a tech sheet that will take you through the process.
OVM
#12 Posted : Thursday, December 30, 2010 1:44:20 PM(UTC)
OVM
This seems like a dumb questions but how do i access the service panel? I used to use a screwdriver on the side to release the clips.
sidfink43
#13 Posted : Thursday, December 30, 2010 2:04:12 PM(UTC)
sidfink43
I am assuming you have the same model as the original post. If so, there are screws that hold it on. If not, post your model number and let's see what you have.
OVM
#14 Posted : Thursday, December 30, 2010 4:59:44 PM(UTC)
OVM
My model is ftf2140es3. I am now having trouble with the water temp and getting a proper spin cycle; water temp is to hot and cloths don't seem to have to much water in them like it won't go into high speed spin. I have no LCD pannel so I don't know what any fault coeds are.
OVM
#15 Posted : Thursday, December 30, 2010 5:11:49 PM(UTC)
OVM
I am getting a 1400 ohm reading on the door switch.
sidfink43
#16 Posted : Thursday, December 30, 2010 5:25:05 PM(UTC)
sidfink43
Ok, here is the service manual which will describe the codes (you have the good model which displays codes by blinking lights)
http://frigidaireservicetips.co...rizontalAxisWasherSM.pdf
OVM
#17 Posted : Thursday, December 30, 2010 5:31:11 PM(UTC)
OVM
and the hot water valve works but cold doesn't.
OVM
#18 Posted : Thursday, December 30, 2010 6:16:10 PM(UTC)
OVM
I tried to run the Diagnostic test but I couldn't get into the test mode.
OVM
#19 Posted : Thursday, December 30, 2010 6:30:42 PM(UTC)
OVM
I got the diagnostic to run every thing worked but the cold water line. I don't under stand how to read the flashing lights of the error code though.
sidfink43
#20 Posted : Friday, December 31, 2010 5:08:31 AM(UTC)
sidfink43
The Service Manual will explain and interpret the codes for you. The flashing lights are error codes.
Guest (10)
3 Pages<123>
