Changed the thermal fuse behind control panel after the oven died during cleaning cycle. Now Top oven is not working - Bottom works fine.
Originally Posted by: dgodin1961  Changed the thermal fuse behind control panel after the oven died during cleaning cycle. Now Top oven is not working - Bottom works fine. DG, You may have an open element thermal fuse, Part number: AP3879224
Located on the back of the oven cavity,or a broken, burnt wire to the elements. The easiest way to check, *** This is a LIVE voltage test, so be careful *** Turn power off the the oven, Dismount the bake element from the oven cavity, and slide element out as far as possible, leave the wires attached. Restore power and program a bake cycle, Check for 220 VAC across the terminals of the bake element, If you have the 220 vac, you have a bad bake element. If you have 120 vac you have lost a power leg, and will need to acces the back of the oven, to check the fuse for open and wiring for damage. Good Luck, :) :) :)
