bseibes
#1 Posted : Thursday, August 28, 2008 6:59:14 PM(UTC)
bseibes
Some time the dryer works and some times it doesn't , I took it apart yesterday and cleaned it tried it it worked fine when i put it back together and put a load in it it wouldn't work then i waited couple of hours and tried it it worked and it dried the load fine. Can someone please explain what is wrong. Thanks a million.:p
libertyappl
#2 Posted : Thursday, August 28, 2008 7:17:21 PM(UTC)
libertyappl
Check your wire connections make sure they are snug.
Nat
Myles.Smith
#3 Posted : Monday, September 1, 2008 11:26:32 AM(UTC)
Myles.Smith
My dryer is having the same problem if you find the cause please let me know what it is.If I get an answer I will let you know.:confused:
dryer does not heat up as high as it use to (Dryer Repair)
by bubba1915 3/8/2014 5:49:40 PM(UTC)
Kenmore Elite Dryer does not heat up (Dryer Repair)
by cjagadheshan 12/13/2011 5:11:32 PM(UTC)
by liz777 1/6/2011 9:11:35 PM(UTC)
by kamputty 4/11/2010 8:40:39 PM(UTC)
by pauleouellette 3/10/2009 12:37:59 PM(UTC)
dryer does not heat up (Dryer Repair)
by tkeemm 2/27/2008 6:37:29 AM(UTC)
by dralonso 2/21/2008 10:52:52 AM(UTC)
