hol99
#1 Posted : 14 years ago
hol99
My dryer won't start during dryer mode. It is a pretty basic dryer. It usually runs and heats during dry mode, but it has stopped. The timer runs all during the cycle, but the only time the motor runs, and the drum actually turns, is during "finish guard" mode, which is an intermittent cycle that just tumbles the clothes for a brief period after the dry cycle has completed. I have checked the thermostats, and have continuity on all but one, which is called the "cycling thermostat", and has four terminals with two red wires and two purple ones. What does this thermostat do? Should I have continuity between the reds, and continuity between the purples. Haven't gotten to the igniters and flame sensors yet. Maybe this weekend.
kayakcrzy
#2 Posted : 14 years ago
kayakcrzy
That thermostat you are talking about is the operating thermostat. From top to bottom, you should get an ohm reading. From right to left, you should not get a reading. If the flame sensor, and the ignitor, were bad, the dryer would still come on, but no heat. If the thermal fuse was bad, it would not come on in that one cycle you are talking about. I have a feeling you have a bad Timer. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
hol99
#3 Posted : 14 years ago
hol99
Do you know of a way I can check the timer, without buying a new one first? Could it possibly be the little circuit board on the unit?
kayakcrzy
#4 Posted : 14 years ago
kayakcrzy
No I cannot. Tom ApplianceEducator.com
#5 Posted : 14 years ago
[COLOR="Blue"]Do you know of a way I can check the timer, without buying a new one first?[/COLOR]
The following may help.
Unplug the unit.
Ste the timer to mid scale any cycle.
BK to BU contacts on the timer should be closed.
I am pretty sure the above are OK and the problem is with the following.
Check the Tan to White contacts. They should be closed fo timed try, air dry and first part of permanent press cycles.
Last part of the permanent press cycle, they switch to close the Tan to BY intermittently to give you the "finish guard"
[COLOR="Blue"]
Could it possibly be the little circuit board on the unit?[/COLOR]
I do not think so, all this controls is the timer motor.
hol99
#6 Posted : 14 years ago
hol99
Thanks. I'm in the electrical business, so I own a couple meters. I will check what you suggested.
hol99
#7 Posted : 14 years ago
hol99
You sir, are a Godsend!! That's exactly what it is!! Checked those contacts, and they were open. Jumpered them out, plugged it in, pressed "start", and viola!! Started humming away. Took the cover off the front of the timer, and I can see exactly where it failed. Thanks a bunch!!!
#8 Posted : 14 years ago
You are welcome
Have a Happy New Year!!
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 14 years ago
