I have a Tappan Double Wall oven. Over ten years old but in beautiful condition The temperature on the ovens is incorrect by approx 25 degrees and 20 degrees. Is there any way to adjust or replace something that can make the ovens true to temperature
Rank: Administration
Thermostat controlled oven: Most thermostats have an adjustment screw which will allow you to make minor adjustments. If that doesn't help, you can replace the thermostat. Digitally controlled oven: There is a way to adjust your oven control board. Read this article.
