Too warm in back to freeze. Tried switching leads again, unable to get water to ice maker using door water dispenser.
Does this mean the sending unit is bad?
I check the valve by swapping the leads as suggested. This Activated the icemaker and caled for water. I assumed the Ice Maker was faulty and ordered a replacement from APP. Everything is installed but the tray will not fill. I checked the fill tube and it is not frozen. Any suggestions would be greatly appreciated.
When you swapped the leads and got water into the icemaker did you get water thru thr door as well. If no its probably your valve. Nat
