ravaginggoatman
#1 Posted : Wednesday, December 15, 2010 4:07:35 PM(UTC)
ravaginggoatman
My Ge side by side refrigerator stopped working, I cleaned the coil plugged it in and an hour later the freezer was at about 0 and the refrigerator was in the 40s. Two days later stopped working again. when we first baught it new about 9 or 10 years ago the day it was delivered it would not get cool, a service man came out and replaced an elcetrical part and have had no problem since then, untill now. Could it be the same part again and if so what might that part be?
thanks, Goatman.
#2 Posted : Thursday, December 16, 2010 3:13:37 AM(UTC)
A model number may help others help you.
Sounds like you have a defrost problem.
To confirm this remove the evaporator cove from inside the freezer so you can see the coils. If they are heavily frosted/iced over then you do have a defrost problem.
Here is a good site with basic fridge repair info.
http://www.applianceaid.com/frig.html
Cannot comment on the repair when it was new. I would need a lot more info.
There are a many things that can cause a unit to stop cooling.
ravaginggoatman
#3 Posted : Thursday, December 16, 2010 3:16:06 PM(UTC)
ravaginggoatman
the model number is gss25psmf,
the freezer fan is running the condenser fan is running, unplugged it over night just plugged it back in to see if it would get cold so far not cooling.
I removed the panel inside the freezer cant see frost as it had been unplugged.
Thanks.
#4 Posted : Thursday, December 16, 2010 6:38:34 PM(UTC)
Here is the parts breakdown.
Sealed system & mother board replacement parts for General Electric GSS25PSMFBS Refrigerator | AppliancePartsPros.com
Give it a few hours to see if you get frost.
Next question is if the compressor is running?
Usually you can hear it also feel it vibrating and it should be warm.
If it is running then either the compressor is toast or you have a leak and am out of freon.
Both of the above are expensive repairs and usually it is better to invest those dollars into a new unit.
ravaginggoatman
#5 Posted : Friday, December 17, 2010 3:35:19 PM(UTC)
ravaginggoatman
compressor does not appear to be running, is cold, no frost on condenser.
#6 Posted : Saturday, December 18, 2010 12:13:54 AM(UTC)
This is probably just a terminology problem but there will not be frost on the condenser (coils under the unit). Frost should be on the evaporator ( coils in the freezer).
OK sounds like it may be a problem with the compressor or it's start relay.
Check that the compressor is getting power.
Check the compressor windings.
You will need a meter for this.
Below are a couple links. The first has better general info, the second has better checking instructions.
Appliance Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Guest (7)
