huberhouse1886
#1 Posted : Friday, August 1, 2008 12:14:52 PM(UTC)
huberhouse1886
Every Summer my ice dispenser freezes up solid with frost rendering my door ice dispenser useless. Is there anything I can do to help?:confused: Is the little trap door for the ice not sealing off properly? Does my actual door need more insulation? The frost build up is not limited to just the door, but also inside the ice maker's dispenser that dispenses it to the door.
huberhouse1886
#2 Posted : Monday, August 18, 2008 11:58:14 AM(UTC)
huberhouse1886
Does any senior tech person know if a new trap door will help my situation? I saw a another blog that had a similar problem and she was advised to change out the ice chute door.
libertyappl
#3 Posted : Monday, August 18, 2008 1:31:28 PM(UTC)
libertyappl
I would have to agree with the flap door not sealing. Try a new one, they aren't that expensive and should solve your problem.
Nat
huberhouse1886
#4 Posted : Monday, August 25, 2008 12:41:46 PM(UTC)
huberhouse1886
Thanks, we will change the flapper door out and give it a try to see what happens. It should be the least expensive fix for the problem.
libertyappl
#5 Posted : Monday, August 25, 2008 1:22:47 PM(UTC)
libertyappl
You're welcome
I hope that takes care of the issue
Nat
Guest (6)
