3 Pages<123>
#11 Posted : Saturday, December 11, 2010 2:28:16 PM(UTC)
Every time when you do the continuity test, the wires should be disconnected. The microwave MUST be unplugged.
I would just replace the switches. Especially because the substituted switch is absolutely inexpensive. This switch has three terminals compare to the OEM switch which has just two. You have to carefully break off the terminal marked NC.
raylamm05
#12 Posted : Monday, December 13, 2010 6:36:48 AM(UTC)
raylamm05
Which switch should I order?
Ray
raylamm05
#13 Posted : Monday, December 13, 2010 6:37:46 AM(UTC)
raylamm05
Which switch should I buy?
Ray
#14 Posted : Monday, December 13, 2010 12:50:00 PM(UTC)
Ray,
As I posted earlier the substituted switch Part number: AP3186054
raylamm05
#15 Posted : Saturday, December 18, 2010 12:52:27 PM(UTC)
raylamm05
I replaced the switch. The symptoms are the same. Nothing works. What next?
Ray
Ray,
#16 Posted : Sunday, December 19, 2010 3:31:02 PM(UTC)
If you have the schematic for the microwave, can you post it here?
raylamm05
#17 Posted : Tuesday, December 21, 2010 12:41:31 PM(UTC)
raylamm05
See if this attachment helps.
Ray
Ray
raylamm05 attached the following image(s):
#18 Posted : Tuesday, December 21, 2010 6:07:50 PM(UTC)
According to the diagram, the secondary interlock switch in this model is the bottom switch. So if you replaced only the upper switch, replace the bottom switch too.
raylamm05
#19 Posted : Wednesday, December 22, 2010 5:18:00 AM(UTC)
raylamm05
I replaced the bottom switch only.
Ray
#20 Posted : Wednesday, December 22, 2010 2:46:20 PM(UTC)
Ray,
Looks like the problem is a bad power relay on the control board.
- The control board Part number: AP3205428
Ge Advantium:Convection Works, Microwave doesn't work (Microwave Repair)
by domsue 1/30/2014 10:30:17 AM(UTC)
BRAND NEW microwave doesn't work (Microwave Repair)
by disneydenise 4/12/2010 5:48:35 PM(UTC)
Frigidarire Microwave doesn't work (Microwave Repair)
by ridge 9/29/2009 6:25:06 AM(UTC)
light under microwave doesn't work (Microwave Repair)
by denden8148 4/20/2009 9:48:42 AM(UTC)
by Novice 12/7/2008 10:37:44 AM(UTC)
3 Pages<123>
