cozmo
#1 Posted : Wednesday, September 26, 2007 2:20:04 PM(UTC)
cozmo
When we go to turn on the Dryer it just makes a buzzing sound, the Tumbler does not spin. I have opened up the top & the belt looks fine. Please Help. Thanks :)
richappy
#2 Posted : Wednesday, September 26, 2007 6:09:11 PM(UTC)
richappy
Probably a bad motor, burnt start winding. I usually measure current to confirm.
You can pull motor and wire 115 volts per the wiring diagram to confirm also.
fasteddie1
#3 Posted : Thursday, September 27, 2007 7:04:58 AM(UTC)
fasteddie1
I have the same problem with a GE model. Took the motor out seems to spin ok. Test ok I don't know what else to check or replace.:confused:
ROPER Dryer not spinning (Dryer Repair)
by tt2601 10/3/2013 12:55:01 PM(UTC)
Amana Dryer not spinning (Dryer Repair)
by ccasler 3/8/2010 7:40:19 AM(UTC)
by jkammer 11/2/2009 9:41:04 AM(UTC)
