matt b
#1 Posted : Tuesday, September 25, 2007 7:18:05 AM(UTC)
matt b
Problem: Tub won't spin to wring out load
Discovered problem when the washer was supposed to be in the final spin cycle. The water was pumped out; the motor was running; but the tub was not moving.
I shut the unit off and then retried a few times to see if it would spin...no luck, it just pumped out the remaining water in the tub. Next I tried to see what would happen at various points of a complete wash cycle...nothing happens. I assume nothing can happen because there is no water in the tank!
Any help or ideas out there?
Thank you,
Matt
richappy
#2 Posted : Wednesday, September 26, 2007 1:40:17 AM(UTC)
richappy
You have a busted coupler, just remove front panel and motor. You will need to replace the motor coupler. Click on your model # above to order it.
matt b
#3 Posted : Wednesday, September 26, 2007 3:51:05 AM(UTC)
matt b
Good morning Richappy,
Thank you for the advice. Fortunately, it is an inexpensive part.
Matt B
