Dryer Spins And Works Like Normal But No Heat, Vent Is Clear.
Originally Posted by: SUPERCALIFRADULISTIC Dryer Spins And Works Like Normal But No Heat, Vent Is Clear. BBBBBBBBBBBBBBB
You may want to start the troubleshooting from the thermal fuse (#6 on the diagram) which has to be checked for continuity. If the thermal fuse is open, replace it together with the cycling thermostat. - The thermal fuse Part number: AP3132867
Originally Posted by: Gene You may want to start the troubleshooting from the thermal fuse (#6 on the diagram) which has to be checked for continuity. If the thermal fuse is open, replace it together with the cycling thermostat. - The thermal fuse Part number: AP3132867
Not a thing i didnt know if i was typing in the right spot. thanks
