hatnem
#1 Posted : Wednesday, August 20, 2008 2:59:24 PM(UTC)
hatnem
I have a Neptune washer- model #MAH5500BWW. Console touch pad lights, but I cannot change any of the settings or turn the machine on/off. I tried doing the diagnostics test but the machine does not respond when I try to go into the service mode. I unplugged to try to reset, no change. I replaced the control panel as well, but no change. Any ideas? Serial number is A9700679EJ, I think from 2002. Thanks!
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 9/13/2020 5:18:38 PM(UTC)
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 10/26/2018 8:36:20 AM(UTC)
Maytag neptune washer logic board (Washer Repair)
by Busch58 1/10/2018 1:09:35 PM(UTC)
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 11/17/2015 12:56:58 PM(UTC)
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 4/16/2015 5:22:16 PM(UTC)
maytag neptune washer MAH9700AWM wont spin (Washer Repair)
by biztyke 4/9/2015 11:19:06 PM(UTC)
Maytag Neptune Washer Shuts off After Water Fill (Washer Repair)
by kluskc 12/7/2013 9:15:13 PM(UTC)
Maytag Neptune Washer will not spin (Washer Repair)
by BStevens82 5/22/2013 9:55:09 AM(UTC)
Maytag Neptune washer code uc (Washer Repair)
by Jef_R 3/18/2013 3:19:45 PM(UTC)
Maytag Neptune Washer shuts off (Washer Repair)
by HHB 12/5/2012 8:23:26 PM(UTC)
Maytag Neptune Washer Spin Cycle Noise (Washer Repair)
by jayjaysin 8/19/2012 6:14:50 AM(UTC)
maytag neptune Washer (Washer Repair)
by alfonso m 8/18/2012 2:18:19 PM(UTC)
Maytag Neptune washer & dryer reputation (Washer Repair)
by LLLN 8/12/2012 8:26:24 AM(UTC)
by LLLN 8/12/2012 8:25:00 AM(UTC)
Maytag Neptune Washer - cold won't fill (Washer Repair)
by sandylouwhoo 3/30/2012 8:00:23 AM(UTC)
