LostME
#1 Posted : Tuesday, August 19, 2008 2:10:53 PM(UTC)
LostME
I have a Kenmore wall oven Model No. 911.47822100. For some time the oven has been beeping and displaying a F0 code. I was told by a service person, authorized Kenmore repair man, that I needed to replace the ERC. I ordered and replaced the ERC, but the oven is still displaying the same code. I was told by your customer service people that you might be able to help me determine if the ERC that I purchased is bad, or if there is the error is being caused by another part (I have a feeling it could be the key pad?).
kayakcrzy
#2 Posted : Wednesday, August 20, 2008 4:59:32 AM(UTC)
kayakcrzy
It is most likey going to be the touch pad. Which will be the whole front control panel. Tom ApplianceEducator.com
#3 Posted : Wednesday, August 20, 2008 2:27:08 PM(UTC)
Views messages in topic : 27,455
We can help you with the right part number for the control panel if you can post the color of it.
LostME
#4 Posted : Wednesday, August 20, 2008 4:17:40 PM(UTC)
LostME
Gene and Tom, thanks for the replies.
The control panel is white. I believe that the part number is WB36T10444.
Is there any test I can perform to determine if the problem is with the control panel, and not the ERC, short of replacing the panel and seeing if that fixes the problem? These parts are fairly expensive.
Thanks again.
kayakcrzy
#5 Posted : Thursday, August 21, 2008 4:05:14 AM(UTC)
kayakcrzy
Basically we are also at the mercy of the manufacturer, we go to sheet, that tells us what the problem is, and that's that. 90% of the time, they are right. Tom ApplianceEducator.com
#6 Posted : Friday, August 22, 2008 3:47:57 PM(UTC)
You can do a simple test, but it does not 100% prove which part is bad.
Open the control panel and unplug the control panel ribbon from the control board (ERC). Restore the power and monitor the oven for one or two days. If the error code returns then the ERC is bad. If it would not, then the control panel is bad.
Also all GE (manufacturer of your oven) instructions referred this error code to a 50/50 chance to either of the control panel or ERC to be bad. You already replaced the ERC and now is the control panel turn.
LostME
#7 Posted : Tuesday, August 26, 2008 4:49:49 PM(UTC)
LostME
Well, I unplugged the ribbon, and it started beeping and showed the F0 code within five minutes. Unfortunately, it appears that I still don't know if it is the pad or the ERC - although it seems unlikely that I would get a bad ERC as a replacement for the original. Thanks.
#8 Posted : Tuesday, August 26, 2008 7:32:54 PM(UTC)
Originally Posted by: LostME Go to Quoted Post
...it seems unlikely that I would get a bad ERC as a replacement for the original...
Unfortunately defective new parts is not a surprise today but most likely the problem is a bad control panel.
The part number WB36T10444 you mentioned before is the correct part number for the control panel.
LostME
#9 Posted : Thursday, August 28, 2008 1:33:16 PM(UTC)
LostME
I am going to go ahead and return the ERC and replace the control pad. Even if I end up replacing both parts - I'll still come out ahead of having someone repair it for me.
Thanks for all of your help.
#10 Posted : Thursday, August 28, 2008 5:33:20 PM(UTC)
You're welcome. Keep us posted.
