YELOOD1
#1 Posted : Wednesday, August 20, 2008 12:14:25 PM(UTC)
YELOOD1
my microwave was on heating food ,then stop heating and the turn table stop also.everything else works.-need help.
abadfish66
#2 Posted : Wednesday, August 20, 2008 12:20:55 PM(UTC)
abadfish66
Most likely problem is your monitor switch...Part Details - GE Switch - monitor, part number: WB24X830
To get to it, you need to remove the outer case of the microwave. The switch is located on the latch bracket, bottom. Inspect all switches where the terminal meets the plastic housing, look for the plastic to be melted abit around that terminal. The other 2 switches part#'s are wb24x801
