AppliancePartsPros.com
Appliance Repair Help
Trash Compactor Repair
KitchenAid Trash Compactor foot pedal wont' open the compactor
KitchenAid Trash Compactor Model No. Kucc151lpa0
The spring is broken on the foot pedal. Do I need part 2 in the diagram is called the actuator switch or part 7 foot pedal?
Tony, Check the container spring (#33 on the break down diagram). Check how freely is container moving forth and back. Check if the container is not bend. The foot pedal is not spring loaded. Gene.
