Why does my refrigerator leak inside from the hole in the upper right side of my refrigerator. After a while, the water flows out of my frige door.. I have the Ice maker tray inside the freezer part of the refrigerator. John
That is because you defrost drain hole is plugged up, and when the refer goes into defrost instead of it going down the drain it runs out to the freezer fllor and down into the freshfood section.
To fix, you will need to remove the back of the freezer section, use hot water an a turkey baster to clear the drain located under the evaperator.
