Logan29
#1 Posted : Sunday, November 21, 2010 5:55:12 PM(UTC)
Logan29
Dishwaher doesn't run. When you plug it in and turn the timer, it doesn't do anything. The door switch seems to be fine. When you lock it, 120VAC is present at the motor, but nothing happens, no noises, clicks, anything. I replaced the timer but that didn't make any difference.
#2 Posted : Tuesday, November 23, 2010 2:59:58 AM(UTC)
I cannot find any info on the given model number.
Since you have 120 volts across the motor and it does not run, I would say it is toast.
Logan29
#3 Posted : Tuesday, November 23, 2010 2:41:42 PM(UTC)
Logan29
What tells the motor its time to run? I don't know if this is going to make sense, but I thought that the motor would have voltage to it all the time, and when it was signaled to run it would run. Does the timer contain all the circuitry/logic for the dishwasher to run? The motor performs all the functions of draining, filling and washing? What tells the heating element its time to dry?
#4 Posted : Tuesday, November 23, 2010 3:36:18 PM(UTC)
I cannot find info on this unit so the following is just what is usual.
[COLOR="Blue"]What tells the motor its time to run?[/COLOR]
The timer or the control board.
[COLOR="Blue"]I don't know if this is going to make sense, but I thought that the motor would have voltage to it all the time, and when it was signaled to run it would run. [/COLOR]
No the timer or control board completes the circuit to the motor (applies 120 volts) and then it runs.
[COLOR="Blue"]
Does the timer contain all the circuitry/logic for the dishwasher to run?[/COLOR]
Yes.
Often there is also a keyboard which inputs your selections into the control board.
[COLOR="Blue"]The motor performs all the functions of draining, filling and washing?[/COLOR]
Depends on the unit.
Some units have a separate wash pump and a drain pump.
Some units use the same pump for both washing and draining.
[COLOR="Blue"]What tells the heating element its time to dry?[/COLOR]
The timer or control board.
mennoman
#5 Posted : Tuesday, November 23, 2010 4:01:16 PM(UTC)
mennoman
Have you checked the door switch for continuity. Also check the dw terminal box to make sure you do not have a loose or open connection on the neutral
Logan29
#6 Posted : Wednesday, November 24, 2010 12:29:06 PM(UTC)
Logan29
The door switch seems to be fine. With the switch open, no voltage is present at the motor or any of the other connections, and the opposite when closed.
Its a portable DW, so where is the terminal box at? Now that I know that the motor isn't signaled to turn on, it seems like the motor is the culprit here.
mennoman
#7 Posted : Wednesday, November 24, 2010 2:06:06 PM(UTC)
mennoman
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
mennoman
#8 Posted : Wednesday, November 24, 2010 2:13:28 PM(UTC)
mennoman
You need to check if you have 120v at the motor across neutral and not ground. Are any functions working (filling,indicator lights ect) If not check your power cord for continuity on the neutral side
Logan29
#9 Posted : Wednesday, November 24, 2010 5:36:55 PM(UTC)
Logan29
Looks like there is a short in the power cord. When I move the power wires underneath it runs. I thing I'm gonna replace the power cord and see if issues follow. I didn't have 120v across the motor. I had 120v when I probed the (I think) hot and ground. its running now.
Logan29
#10 Posted : Thursday, November 25, 2010 5:18:48 PM(UTC)
Logan29
Where the power cord connects to the dw; the connectors neutral terminal is blackened, like its been arching. Why I don't know, maybe just normal wear and tear? It looks like if I replace those connectors, everything should be ok. I'll splice the wires together instead and everything should work out fine.
