2 Pages12>
17929
#1 Posted : Thursday, August 14, 2008 2:34:33 PM(UTC)
17929
Second icemaker in stainless frig that was stuck in defrost mode. Replaced and gave 4oz water per instructions. After ice ejected no refill, tried again, same result. Any ideas? Thanks
libertyappl
#2 Posted : Friday, August 15, 2008 10:51:12 AM(UTC)
libertyappl
Test your water valve.
If possible inside the unit is a tag with complete model number
Nat
17929
#3 Posted : Friday, August 15, 2008 12:06:27 PM(UTC)
17929
How do I test the valve?
libertyappl
#4 Posted : Friday, August 15, 2008 12:10:35 PM(UTC)
libertyappl
Switch the leads to the valve then push the water diespenser on the front and look to see if you are getting water to the icemaker.
let me know what happens.
Nat
17929
#5 Posted : Sunday, August 17, 2008 4:32:46 PM(UTC)
17929
I thought the valve was at the bottom/back but there are no leads to the plastic piece where the water supply enters. Where's the valve?
libertyappl
#6 Posted : Sunday, August 17, 2008 6:09:52 PM(UTC)
libertyappl
The valve is on the back near the bottom, take a look at it there are a couple of wires that connect to it.
17929
#7 Posted : Monday, August 18, 2008 2:49:01 AM(UTC)
17929
Swapped leads, water dispensed from door uncommanded, disconnected
libertyappl
#8 Posted : Monday, August 18, 2008 5:35:19 AM(UTC)
libertyappl
That is because the ice maker was calling for water at that moment. I think your fill tube is frozen. Switch the leads back and try to defrost the fill tube.
Nat
17929
#9 Posted : Monday, August 18, 2008 5:10:23 PM(UTC)
17929
Removed power and left door open for an hour, still no luck.
libertyappl
#10 Posted : Monday, August 18, 2008 6:16:25 PM(UTC)
libertyappl
Try to pull the fill tube from the back of the machine (it may be screwed down) and thaw the tube out with a hair dryer or steamer.
Also look inside your refrigerator side and get the complete model number makes it much easier to assist you.
Nat
Ice maker won't fill with water automatically (Refrigerator & Freezer Repair)
by tracymckibben 9/8/2016 6:19:30 PM(UTC)
Ice maker won't fill with water (Refrigerator & Freezer Repair)
by arctic123 12/6/2012 5:26:07 PM(UTC)
ice maker won't fill (Refrigerator & Freezer Repair)
by krzy1957 7/20/2012 1:04:14 PM(UTC)
ice maker won't fill with water (Refrigerator & Freezer Repair)
by bettyjoe 10/27/2011 10:24:50 AM(UTC)
Whirlpool Ice maker won't fill (Refrigerator & Freezer Repair)
by LabTech 8/3/2009 12:26:08 PM(UTC)
2 Pages12>
