2 Pages12>
loweluckie
#1 Posted : Wednesday, September 19, 2007 11:49:53 AM(UTC)
loweluckie
took wires loose on dryer motor to find out where short was dont remember where the wires hook back up please help me by telling me where the wires go thanks
Matt / APP Team
#2 Posted : Wednesday, September 19, 2007 5:23:01 PM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Look on the machine inside the console for the wiring diagram, it should be there on the machine unless someone tossed it. If you cant find it contact us with your email and Ill see if we can email it to you. Always write down or take a picture so you remember where everything goes.
loweluckie
#3 Posted : Friday, September 21, 2007 3:36:58 AM(UTC)
loweluckie
it isnt on the inside of the machine
loweluckie
#4 Posted : Saturday, September 22, 2007 7:16:53 PM(UTC)
loweluckie
no diagram inside
richappy
#5 Posted : Sunday, September 23, 2007 3:23:16 AM(UTC)
richappy
You model # comes up as a washer!
loweluckie
#6 Posted : Sunday, September 23, 2007 6:08:59 PM(UTC)
loweluckie
it is a combo but the model # on dryer motor is s58nxlht-6295 and the part # is 3391898 unit model # lt7000xtw0 serial # mx3716255 and stock # lt7000t
richappy
#7 Posted : Monday, September 24, 2007 1:46:17 AM(UTC)
richappy
Can't find a schematic for your dryer, but will give you wiring ifo.
The heater wires are a larger gauge and usually red, these two go to pins 1& 2 of the motor, no polarity required. The blue wire goes to pin 5, the white/red wire goes to pin 4, and the black wire goes to pin 6. Your centrifical switch should have the wire tabs color coded, unless the label fell off.
If you scrambled the wires going to the motor windings from the centrifical switch, I can look that up later.
sdemiss
#8 Posted : Saturday, November 17, 2007 7:56:18 PM(UTC)
sdemiss
I have a similar problem with wiring. I have a Kenmore Elite Dryer (Model# 110.73952102) and am trying to replace the electronic panel because one of the resistors is fried. I also opened the kick plate to clean a little bit and found a loose red/yellow wire that originates from the moisture sensor @ the electonic panel. Is this something that should be grounded, meaning be left like that, or should it be attached to something?
stretch88
#9 Posted : Sunday, February 10, 2008 9:43:39 PM(UTC)
stretch88
Hey richappy. I am not trying to step on anyones toes, but you said that the white wire goes to pin #4, blue to #5, aren't those two swithched around? Every diagram and motor I am now checking on have blue at pin 4 and white w/red or orange stripe going to pin 5, and as you stated black at pin 6. Just checking. Take care and good luck. I hope to see which way is right. Thanks for all your knowledge, awesome sight.
Jamie
richappy
#10 Posted : Wednesday, January 7, 2009 1:10:29 AM(UTC)
richappy
If I remember right, pin 4 goes to ground sometimes through the door switch and pin 5 goes to the power source, but I presently don't have a dryer to check.
Also, your original motor has a special pulley. Does the new motor have this special pulley? Motor # AP3094242
Guest (6)
2 Pages12>
