sncmeyer
#1 Posted : Tuesday, November 16, 2010 3:43:10 PM(UTC)
sncmeyer
:confused: My oven will not come on. We have replaced the heating element and the thermostat and it still does not come on. I do not use the self-cleaning as I have heard it can mess it up. The range top works including the clock. The range/oven are on different circuit breakers and we even replaced the oven breaker...still not working. Any ideas?
#2 Posted : Wednesday, November 17, 2010 3:04:44 AM(UTC)
Replacement parts for S156 models | AppliancePartsPros.com
Here is a manual
16000446 Jenn-Air Electric Range Service Manual - ApplianceDigest.com
You may have to join the site to get the manual but it is a good site.
It could be the hi-limit thermostat (Item 5 in Section 8) is open.
Remove power from the unit.
Remove the wire from one side of the thermostat and measure across the thermostat with a meter.
Should be 0 ohms.
sncmeyer
#3 Posted : Saturday, November 20, 2010 6:56:51 PM(UTC)
sncmeyer
Thanks for your reply Denman however I am a bit of a newb here and I still have some questions. First, I think I found it but it is way back under the burners on the stove top. Do I need to tear the whole top off the thing to get to it. Second, if it is open then how do I close it, of do I just replace it.
Thanks for your help.
#4 Posted : Sunday, November 21, 2010 2:05:30 AM(UTC)
I cannot be much help here as I have never pulled one of these apart.
Hopefully someone else will jump in who has.
Most of them are not resettable.
If they are resettable, they usually have a red button.
