2 Pages12>
Shane5223
#1 Posted : Monday, November 15, 2010 6:00:43 AM(UTC)
Shane5223
My fridge has recently been staying a little warmer than usual. I changed the setting to the coolest a couple of weeks ago and that seemsed a bit better...Now the freezer and fridge seem to be working intermittently...
Any suggestions?
Joe / APP Team
#2 Posted : Monday, November 15, 2010 7:45:37 AM(UTC)
Joe / APP Team
Any suggestions?
Shane,
Check the back wall of the freezer compartment,
For "snow" or ice,
Your description would indicate a probable defrost problem,
The first indication would be frost or ice building up on the evaporator, and restricting the air flow in the unit, and causing ice to form on the back wall.
Good Luck,
:cool: :cool: :cool:
Shane5223
#3 Posted : Monday, November 15, 2010 8:07:14 AM(UTC)
Shane5223
Would this be on the inside of the freezer? If so, there is no frost buildup...
Joe / APP Team
#4 Posted : Monday, November 15, 2010 11:09:42 AM(UTC)
Joe / APP Team
Shane,
Yes,
It would be the back wall inside the freezer.
And you also stated both the fridge and freezer have an intermittent cooling situation, correct ?
Based on that, I would have to suspect the ADC timer board
Part number: AP4909015
or the temperature control
Part number: AP2151626
Of course there are other possibilities( sealed system failure, defrost thermostat, etc.)
But that's were I would start if it were me.
Good Luck,
Shane5223
#5 Posted : Monday, November 15, 2010 12:20:21 PM(UTC)
Shane5223
So, I have the back panel off where the condenser unit is...I open the doors to the fridge and when cooling is called for a humming sound comes from the condenser for about 3 seconds and then stops...could this be the issue? Shouldn't it run until the temp is reached?
The fan to the coils is running constantly...
The two parts you speak of, is there any way to check if they are bad before purchasing them?
Joe / APP Team
#6 Posted : Monday, November 15, 2010 12:38:30 PM(UTC)
Joe / APP Team
Shane,
Now that's a better description, and more informative.
It now sounds like a bad compressor relay/overload assembly.
Part number: AP4367355
Part number: AP4315853
If you remove the assembly from the side of the compressor, and shake it, if you hear or feel a rattle, you've got a burnt PTC assembly inside and you'll need to replace the part(s).
Thanks for the update and added information,
Good Luck,
Shane5223
#7 Posted : Monday, November 15, 2010 12:50:31 PM(UTC)
Shane5223
I have removed this and do not hear any rattle...Is there another way to see if it is functioning properly?
Shane5223
#8 Posted : Monday, November 15, 2010 2:14:19 PM(UTC)
Shane5223
I unplugged it for about 10 minuets and when I plugged it in the compressor ran for a good minute or so and then stopped...When it tried to go again, I could hear a slight wine, then a click and then nothing?
Joe / APP Team
#9 Posted : Tuesday, November 16, 2010 5:36:56 AM(UTC)
Joe / APP Team
Shane,
We're back at a bad relay / overload assembly, or a sealed system failure.
You're not going to be equipped to do a sealed system repair(special tools, refrigerant , etc.)
Do you have access to a multi meter, so yo can test circuits and voltages at the relay or compressor ?
Let us know, and we can get you the information, and get you up and running.
Good Luck,
Shane5223
#10 Posted : Tuesday, November 16, 2010 5:46:56 AM(UTC)
Shane5223
I Have A Multimeter...thanks For Your Help!
Guest (6)
2 Pages12>
