richappy
#1 Posted : Wednesday, August 13, 2008 1:54:36 PM(UTC)
richappy
Lady says it drops in and out on spin. Seems like a bad motor/inverter Part #
WH20X10045. Hope someone knows about this less than 2 year old washer.
Thanks in advance.
abadfish66
#2 Posted : Wednesday, August 13, 2008 1:57:40 PM(UTC)
abadfish66
What is the led on the invertor doing?
richappy
#3 Posted : Wednesday, August 13, 2008 3:46:46 PM(UTC)
richappy
Will look at the washer on Friday. She says it works ok in agitate, just drops out in spin. If the LED is solid is this a bad inverter??
abadfish66
#4 Posted : Wednesday, August 13, 2008 10:34:14 PM(UTC)
abadfish66
When motor is operating normally, and running, the LED blinks at a constant rate of ½ second on and ½
second off.
When motor is operating normally, and idle, the LED blinks at a constant rate of 1 second on and 1
second off.
Motor/Control error condition - LED is on for .25 seconds and off for .25 seconds for a specifi ed number
of times, during a 6-second period. The 6-second cycle repeats continuously.
1 second on 1 second off---normal
.5 sec on .5 sec off--------normal
1 flash--------------------long stop time------replace motor
2 flash--------------------slipping belt--------check belt
3 flash-------------------corrupted software---replace motor
4 flash-------------------mode shift circuit failed-check mode shifter coil
5 flash-------------------not known-----------replace motor
6 flash------------------locked rotor----------make sure system is free
7 flash-----------------lid switch did not open---check lid switch
8 flash-----------------motor overheated------make sure system is free
9 flash----------------brake resistor open------replace motor
on 2,4,6,7 & 8 flash errors, if no system error are found replace motor.
Critical Errors, #1, #2, & #7, will prevent inverter/motor from operating.
To clear errors, disconnect power until an audible clicking sound is heard when the inverter capacitor
discharges (approximately 15 seconds). Open and close the lid 5 or more times in any 12-second period
within the first 30 seconds of power-up. Errors will not clear if washer is in either agitate or spin mode.
richappy
#5 Posted : Thursday, August 14, 2008 2:54:57 AM(UTC)
richappy
Thanks for the info, will test Friday.
Update GE washer spin dropout (Washer Repair)
by richappy 8/15/2008 3:22:53 PM(UTC)
