greatdeals_007
#1 Posted : Saturday, November 13, 2010 6:26:05 AM(UTC)
greatdeals_007
I have a Uline beverage center which is a small referigerator for holding drinks. It stopped getting cold and is completely hot inside.
I am wondering if it would be worth fixing or not. Can you give me some suggestions on what the issue might be, estimate to fix?
I realize you would probably have to see it but then again people may have seen this issue before and would know what to look for.
thank you
#2 Posted : Sunday, November 14, 2010 3:20:57 AM(UTC)
A model number may help others help you.
Check to see if the compressor is running.
You usually can hear it also you should be able to feel it vibrating and it should be warm.
If it is running then it is time to get a new unit as fixing it will cost more than it is worth.
If it has an interior light, does it work?
Is it making any noise re: clicking as the compressor tries to start?
mnagode
#3 Posted : Sunday, November 14, 2010 3:03:10 PM(UTC)
mnagode
I have a uline 75r that has the same problem. The light works so I know it has power. I do not hear the compressor running running nor do I hear any clicking when I adjust the temp. control.
#4 Posted : Monday, November 15, 2010 1:56:24 AM(UTC)
mnagode
I do not have info on the unit but it sounds like a simple fridge setup.
You could check to see if the compressor is getting power (120volts AC).
If not you probably have a thermostat problem.
Unplug the unit and measure across the thermostat contacts, should be 0 ohms.
Be sure to detach at least one wire to the thermostat. This prevents you from reading an alternate/parallel circuit path.
If you do not have a meter you could do the following jiggery pokery.
Unplug the unit.
If the thermostat has just 2 contacts, remove them from the thermostat.
Short them together.
Tape them up so they cannot short to anything else.
Plug the unit in.
If it fires up then your thermostat is shot.
If it is getting power then the following should help checking other components.
Here are a couple good links.
http://www.applianceaid.com/frig.html
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
whatsnext
#5 Posted : Tuesday, June 7, 2011 1:01:56 PM(UTC)
whatsnext
My 75FF uline combo only gets slightly cold. not enough for ice or even really to chill the cans surface. Fans work, compressor is running, coils are clean, but barely any cold air. Anyone have suggestions?
#6 Posted : Tuesday, June 7, 2011 4:38:37 PM(UTC)
Not familiar with this unit but with luck it is a standard type of system.
Remove the freezer cover so you can see the evaporator coils.
If they are heavily iced/frosted over you have a defrost problem.
If there is no frost or only frost in one area then you have a compressor problem or are out of freon or are low on freon.
All of these will be expensive repairs so usually it makes more sense to invest those dollars in a new unit.
Lannyv
#7 Posted : Saturday, April 29, 2017 8:26:27 PM(UTC)
Lannyv
I also have a u-line 75r and since I installed the thermostat has gone out 4 times, anywhere from 2 to 5 years apart. I have this unit on my boat so I installed a bypass switch, there's a place for it right below the thermostat dial. The problem is a faulty thermostat and although many repair facilities acknowledge that I am lucky to get 3 to 5 years u-line refuses to acknowledge their problem. The price for a new one is from $35 to $50 dollars and it's not hard to install. You will need to access the rear of the box so look on line for u tube videos. Other than that it's a great box.
