I Hit start, button, then all lights flash on display panel, then you hear 3 beeps, and you'll see the following Err,45,pau, on the display then the # 45 stays lit on display. I checked for error codes on frigidaires website and there's no such number listed. I'm thinking it is the time for wash cycle but what do I know I'm a General Contractor and can build the entire house top to bottom but the appliances in them lol..
Rank: Administration
Groups: Administrators
First off if its under a year old I would check on the warranty if its in effect thye should come fix it for free.
The only thing I could find is PAU is PAUSE and 45 is the length of the normaul wash cycle. I am assuming it means the cycle is pausing with 45 minutes remaining. Now as far as the 3 beeps this is all I could find:
3 beeps/e30: Drum overfilled
Possible cause: inlet valve, pressure switch or control board failure.
Possible solution: Do not open door, select drain/spin to remove water, restart cycle.
I also found a listing that says e45 is a bad control board.
I would look inside the washer for a wiring/diagnostic sheet that will give the test procedures.
That's basically what I found out also, except the E45 code. I actually emtied the dryer, hit spin, cancel, pause and every time Lights would flash, 3 beeps, then pause. and 45 remanined. I did infact call the distributer I purchased the units from and you know how it goes, "I'll have them call you" Unfortunately I live in a small town in Gods country PA lol. If I wasn't in the service business myself I would have lost it a long time ago with them. I'll put a call into them again and hope for the best. til then I'm in the dog house since my wife is going to laundry mat because I "Insisted on front loaders" Thankyou for your time with this matter, Kevin
I have a Frigidaire front loading washer that is just over a year old. The door locks, at the point when the water should start, I hear a faint click, but no water. It beeps once.
A local repairman told me over the phone to check the boot. I found a twist tie, water and detergent in the boot. That wasn't it.
I don't know what to do next.
Originally Posted by: Survivor  I Hit start, button, then all lights flash on display panel, then you hear 3 beeps, and you'll see the following Err,45,pau, on the display then the # 45 stays lit on display. I checked for error codes on frigidaires website and there's no such number listed. I'm thinking it is the time for wash cycle but what do I know I'm a General Contractor and can build the entire house top to bottom but the appliances in them lol.. Hi, I'm having the same exact problem. Any luck? I guess it's a good thing that you're the only other person I found with the same problem. Thanks.
HI everyone,
I have the same error! Were any of you able to fix it? If so how?
ERR message 3 beeps and shows PAU
I am thinking control board failure and wondering if I need to call a repairman or if I can fix it myself.
My Frigidaire dishwasher lights up to start and the door locks but nothing else happens ... No water entering or noise...
