papilcher
#1 Posted : 14 years ago
papilcher
I need instructions on how to replace the Drive Coupling
magician59
#2 Posted : 14 years ago
magician59
Here's a parts breakdown drawing. It looks like the coupling just pulls off the motor shaft. Replacement parts for WHIRLPOOL KSB5WH4 5 - Speed Blender | AppliancePartsPros.com
papilcher
#3 Posted : 14 years ago
papilcher
I tryed to pull the coupling off to no avail. ewhat now?
magician59
#4 Posted : 14 years ago
magician59
I would try to see if it will unscrew from the motor shaft, then. To do this, you will need to open up the case (screws on bottom), and secure the motor from spinning by inserting a tool like a screwdriver into the armature. Be very careful not to harm the windings of wire. Then try to unscrew the coupling (probably reverse threaded). Don't force it if it doesn't work that way.
NONAMEGIVEN79
#5 Posted : 14 years ago
NONAMEGIVEN79
Testing For Customer
NONAMEGIVEN79
#6 Posted : 14 years ago
NONAMEGIVEN79
Test For Customer
