Broiler works fine......bottom oven does not heat up at all or very very slowly. Ignition switch element heats up and stays on...very little gas flowing thru the part in the oven that kicks in once oven is turned on.
Help.
Lenny,
Originally Posted by: magician59 Thank you soo much for your prompt responce ! I will replace and let you know what happened. kindest regards, Lenny:)
