![UserPostedImage](http://file:///C:/Users/Jesus/AppData/Local/Temp/moz-screenshot.png) ![UserPostedImage](http://images.drillspot.com/pimages/3323/332338_300.jpg) I have just installed this gas valve on my furnace and I'm now reconnecting the red and white wires from both the powerpile and the thermostat. I need to know where the red and white wires connect on the terminal block. I know the terminal is marked PP and TH, for powerpile and thermostat, but I need to know where the red and the white cables connect for each.
Make and model number of unit you installed on.
Peerless G560-W-S is the unit I installed the valve on.
Originally Posted by: lqbano ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Peerless G560-W-S is the unit I installed the valve on. Try IO&M Manuals
