specialfx
#1 Posted : Saturday, October 30, 2010 6:34:39 AM(UTC)
specialfx
I have also disconnected the door lock switch and temp sensor and it still does it. Any ideas?
#2 Posted : Sunday, October 31, 2010 2:21:08 AM(UTC)
Please use posr reply in this thread.
Opening a new post will make it difficult to follow what is going on.
Here are your parts, includes a wiring diagram.
Replacement parts for MAYTAG MERD750BAB Range - S/c F/s Ele | AppliancePartsPros.com
It looks like the lock switch is just a Normally Open switch (only 2 wires) so disconnecting should have fixed the problem if the switch was the problem.
You could check the sensor with a meter, see the below link but I do not think that is the problem.
I am assuming you unplugged/removed power from the unit when you worked on it and you still have the problem re: the board did not reset.
Unfortunately it sounds like the control board is toast.
Stove info site
http://www.applianceaid.com/elecrange.html
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Maytag range oven (Oven Repair (including Ranges and Cooktops))
by C Hardin 10/30/2014 4:23:34 PM(UTC)
Maytag range lower oven not heating (Oven Repair (including Ranges and Cooktops))
by KA123 9/8/2014 6:10:19 PM(UTC)
Maytag Range Bake Light Flashing (Oven Repair (including Ranges and Cooktops))
by carlking2 12/26/2013 12:31:10 PM(UTC)
maytag range orifices (Oven Repair (including Ranges and Cooktops))
by chadk66 8/31/2013 3:38:29 PM(UTC)
Remove Maytag Range GlassTop, How to (Oven Repair (including Ranges and Cooktops))
by BobYates 4/7/2012 5:58:49 PM(UTC)
Maytag range clock control (Oven Repair (including Ranges and Cooktops))
by res04n70 12/27/2011 5:17:42 AM(UTC)
Maytag range (Oven Repair (including Ranges and Cooktops))
by txgbe270 8/21/2011 5:07:52 PM(UTC)
Maytag Range / MER5755QAQ (Oven Repair (including Ranges and Cooktops))
by jeffro390 6/6/2011 9:26:31 AM(UTC)
Maytag Range (Oven Repair (including Ranges and Cooktops))
by ADAMS48 6/1/2011 6:11:39 PM(UTC)
by Sanco777 5/13/2011 9:38:57 AM(UTC)
Maytag range. Cooktop functioning, but oven just says OFF (Oven Repair (including Ranges and Cooktops))
by watkinsnc 11/21/2010 10:21:52 AM(UTC)
Maytag Range lower bake element won't work (Oven Repair (including Ranges and Cooktops))
by donnabass8 11/17/2010 11:40:30 AM(UTC)
Any idea of naming scheme for Maytag ranges? (Oven Repair (including Ranges and Cooktops))
by rtom 11/9/2010 8:38:29 AM(UTC)
by specialfx 10/29/2010 2:59:51 PM(UTC)
