I am having a error message F-7 appear on the control panal. I can press
1 min 2 min 3 min 4 min 5 min, the microwave will run for 1 min' stops
running F- 7 appears. Please if one of you pro know what it is???
Let me know.
John
Originally Posted by: 95b873 I am having a error message F-7 appear on the control panal. I can press
Let me know.
John John, The F7 code on your microwave, indicates that there is a power supply problem the the magnetron circuit(open thermostat, loose wire, bad circuit board, etc.) If you have reset the breakers, and the microwave is cool, and you still get the F7 code, unless you have experience with hi voltage,capacitors and transformers, I reccomend you have someone with more knowledge,experience take over. :cool: :cool: :cool:
