jlfrost
#1 Posted : Wednesday, October 27, 2010 7:22:26 PM(UTC)
jlfrost
does anyone know how to get to the actual door switches to make sure they are lined up correctly or broken? i can see them but cant get to them. i would appreciate any helpful advice. thanks.
Joe / APP Team
#2 Posted : Thursday, October 28, 2010 10:50:50 AM(UTC)
Joe / APP Team
JL,
Looks like you gave us a serial number, instead of the model number.
Is this microwave part of a wall oven combination ?
If you could, please supply us with that as well.
Thanks,
:confused: :confused: :confused:
jlfrost
#3 Posted : Thursday, October 28, 2010 11:30:31 AM(UTC)
jlfrost
sorry about that . this should be the model...kemc308kss01. yes it is a part of a built in oven.
Joe / APP Team
#4 Posted : Thursday, October 28, 2010 2:18:47 PM(UTC)
Joe / APP Team
JL,
You most likely have a blown fuse, there's two.
You can access both, by removing the control panel, after removing power to the unit
1. Unplug oven or disconnect power.
2. Open the microwave oven door, remove
the two flat-head screws from the bottom
of the control panel frame, and remove the
frame
3. Remove the four screws from the front
subpanel and remove the subpanel assembly
4. Disconnect the P1 and P2 connectors from
the microwave and lower oven control board
connectors and set the panel assembly aside
5.
To remove the monitor fuse holder:
a) Remove the fuse from the fuse holder.
b) Disconnect the two wire connectors
from the fuse holder terminals.
c) Remove the screw from the fuse holder
and remove the fuse holder
To remove the secondary interlock
switch:
a) Remove the two mounting bracket
screws from the front of the switch
holder on the left front side of the MW
oven, and remove the holder
b) Disconnect the blue (COM) and white
(N.O.) wires from the switch terminals.
c) Raise the locking tabs and pull the
switch off the pins and out of the switch
holder
6.
To remove the primary or monitor interlock
switch:
a) Place the blade of a flat-blade screwdriver
between the switch body and the
holder. Twist the blade until the switch is
free of the tabs, and remove the switch
from the holder.
To access the M/W line fuse,
You'll need to remove the unit from the cabinet, and remove the top panel.
You'll find the line fuse located on the back wall in the holder.
Good Luck,
