malibu3426
#1 Posted : Wednesday, October 27, 2010 9:22:09 PM(UTC)
malibu3426
The machine is level but make excessive noise during spin cycle. I took front off machine and ther are lots of small rubber pieces in the bottom of the machine.
Joe / APP Team
#2 Posted : Thursday, October 28, 2010 10:46:41 AM(UTC)
Joe / APP Team
Malibu,
I'm not sure what you've got ???
I wander, if you've got a warn out set of damper pads,
A bad radial bearing(loud grumbling,rumbling noise).
A bad tub bearing / tub seal assembly(have you noticed any leaking,if your bearing has seized to the transmission, it could be spinning in the tub , you may want to observe the black rubber seal on the bottom of the outer tub, that surrounds the transmission case, and put the machine in the psin cycle and see if it turns, it should not ).
You may have a combination of symptoms, but you will be able to figure that out, as you do these checks.
Good Luck,
:cool: :cool: :cool:
