I wake up in the morning and saw there is no power in the microwave-even the clock & lights are not working. I tried switching to 3-4 outlets but no luck. any idea where to start it from?
The main line fuse is probably blown. This can happen if it is weak; or there may be another cause. It will be inside the cabinet, very close to where the cord enters. Some are 15-amp; but most are 20-amp fuses.
Originally Posted by: magician59 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The main line fuse is probably blown. This can happen if it is weak; or there may be another cause. It will be inside the cabinet, very close to where the cord enters. Some are 15-amp; but most are 20-amp fuses. Is there any diagram or instruction available?
Thanks for reply. confused little bit - do i have to take out the microwave from cabinet?
If it's installed above a counter or range, you must first uninstall it.
