nutbushchris77
#1 Posted : Tuesday, October 26, 2010 4:11:20 AM(UTC)
nutbushchris77
I bought a new blower wheel yesterday to put on my dryer. I had to pry the old one off. How do I put the new one on without tearing something up????:confused: :confused:
#2 Posted : Tuesday, October 26, 2010 4:26:22 AM(UTC)
Here is a parts breakdown
Replacement parts for YE225LV models | AppliancePartsPros.com
Do not know why this should be a problem.
The new wheel should just push on once the shaft flat is lined up with the flat in the wheel.
Then the cir clip is put back on to hold it in place.
nutbushchris77
#3 Posted : Tuesday, October 26, 2010 4:37:00 AM(UTC)
nutbushchris77
Well I tried slipping it on and it was getting tough and I didn't know if it was suppose to be that tough. So I stopped to ask the pros before I tore something up.
So its ok to put a little force behind it...
#4 Posted : Tuesday, October 26, 2010 5:23:43 AM(UTC)
"a little force behind it" would be the operative words.
I would pull it back off and check the the motor shaft does not have burr on it and that the inside of the blower wheel hole is smooth all the way. If both are OK then a little force pushing it on should not hurt anything.
Guest (5)
Restricted airflow after repairman installed new blower wheel (Dryer Repair)
by Guest 6/1/2024 5:28:38 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
Alternate blower wheel for dryer (Dryer Repair)
by Guest 5/6/2023 5:23:57 AM(UTC)
wgd5300sq0 new dryer motor and blower wheel. But blower wheel keeps falling off (Dryer Repair)
by Ebnuno 2/6/2022 7:55:20 AM(UTC)
Maytag DE 410 Blower Wheel Broken (Dryer Repair)
by Eeshen 12/26/2018 7:06:34 AM(UTC)
dryer blower wheel replacement (Dryer Repair)
by lancehenley1 12/4/2018 11:42:59 AM(UTC)
Blower wheel repair (Dryer Repair)
by mrflv2bwl 3/22/2016 12:24:42 PM(UTC)
Not heating after blower wheel replacement (Dryer Repair)
by patrickjwoods 3/16/2014 10:57:47 AM(UTC)
lea30aw blower wheel (Dryer Repair)
by ableman 4/12/2013 10:10:57 AM(UTC)
replace blower wheel (Dryer Repair)
by Jlski 10/9/2012 12:18:25 PM(UTC)
How to remove blower wheel from motor? (Dryer Repair)
by John B P 6/27/2012 6:20:35 AM(UTC)
Dryer Blower Wheel Coming Loose (Dryer Repair)
by cjoyner 2/25/2012 7:51:56 AM(UTC)
blower wheel repair (Dryer Repair)
by mrflv2bwl 1/16/2012 1:12:55 PM(UTC)
Dryer Repair, Blower Wheel for dryer (Dryer Repair)
by Darleneg2 1/14/2012 11:27:18 AM(UTC)
